Re: 1951 cub quits when hot
Posted by bowman316 on September 06, 2014 at 21:34:34 from (68.33.248.144):
In Reply to: 1951 cub quits when hot posted by Denny ('60 Lo-Boy) on September 06, 2014 at 06:56:17:
I just put the tractor back together today, I just have to wait 24 hours for the create a gasket to dry to add coolant.
It almost has to be a spark issue, cuz if it starts cold, the carb should be fine. nothing changes down there when it gets hot. next time it dies hot, ill check for spark.
I also changed the plugs, they dont make champion 15a's anymore, so I got 21d's which is what was in there, but 15a is whats in the manual. the problem with owning a 1951 tractor.
3 out of 4 plugs were rust brown on the tip, the other one was black
