broke a cam gear in a farmall m
Posted by nick roepk on September 08, 2014 at 07:57:50 from (173.23.81.172):
hello, i put a live pump on my 51 farmall m, it worked fine till i was going down the road and suddenly the motor spun down with no power as if i had pushed in the kill switch so i did run threw of my check list the motor would turn over it had fuel and power to the coil so i pulled the cap of the distributor and the rotor was not turning so i pulled the pump/distributor off and the gear for the cam shaft had split. so we drug her back to the shop and pulled the gear out now it is a three hole cam gear. my question is can i get a heavier gear out of a later model of tractor and if so what is the best one to use with this live pump? second off how do i time the cam with the new gear? and at this time i may compleatly rebuild the motor.
