Re: broke a cam gear in a farmall m
Posted by D Slater on September 08, 2014 at 11:06:54 from (184.14.168.53):
In Reply to: broke a cam gear in a farmall m posted by nick roepk on September 08, 2014 at 07:57:50:
Yes line the crank and cam gear marks up. If one gear has 2 marks put the one mark gear mark in the center of the two.
If getting a used IH gear look for one with the number on it ending in DB. DA also works but is machined to be a little less of a press fit on the cam.
Aftermarket sells new gears now, probably this YT site still sells them.
