Re: Farmall M Stops moving/PTO while mowing
Posted by D Slater on September 10, 2014 at 16:18:14 from (184.14.168.53):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on September 10, 2014 at 15:52:46:
Was the lower transmission shaft turning also along with the constant mesh gear when you blocked the wheels and looked in. Originally you said 1 through 4 speeds and the pto didn't work. Lower shaft is probably broke inside a gear or a key is no longer retaining a gear to shaft. Gear spinning on shaft and shaft not turning. Unlikely that both the 3,4 and 1,2 gears both have a stripped key. Since 1 to 4 didn't work when tractor stopped I think the problem is toward the front, inside the constant mesh gear or inside the 3 and 4 double gear.
