Re: Need steering seal part # (SA)
Posted by Rick on January 02, 2001 at 16:30:06 from (204.87.128.101):
In Reply to: Need steering seal part # (SA) posted by David A on January 02, 2001 at 05:50:44:
a suggestion... Even after you replace the seal, when water runs down the steering shaft when it gets wet, it will build up on the top of the seal and want to run inside the steering box. Over time, the bottom of the box fills up with water, which causes the bearing on the output shaft to rust and get loose. Once this is loose, the lower bushing gets worn out as the output shaft wobbles. The steering will get real loose when this happens (the output arm goes up and down due to the wear). Also, the lower seal will be damaged and the box will leak oil. All in all, it stinks! You can reduce the amount of water trying to get into the box by wraping electrical tape (use red so it matches) around the shaft an inch or so above the steering box. Build up about 1/8-1/4 inch thickness. The water will run down the shaft, get diverted by the "drip edge" you have made, and not make it to the box. As I recall, the Super-A has the two piece steering shaft, with the universal joint in the middle (could be wrong). My 100, which is basically a Super-A, has a long single-piece shaft, so there is even more surface for the water to run down. My steering box was so damaged with water that even after rebuilding it the lower seal still leaked, due to pitting in the output shaft. I wound up using the fairly common trick of replacing the oil level check plug with a zerk fitting and filling it up with grease instead of oil. The grease doesn't leak, and my yard no longer smells like 90 Weight gear oil :-)
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
