Re: h4 magneto 180 off
Posted by Janicholson on September 13, 2014 at 12:24:20 from (74.60.94.18):
In Reply to: Re: h4 magneto 180 off posted by calcubman on September 13, 2014 at 12:17:07:
I wish I was looking at it. If the mag can be rotated on its mount in the correct CCW in the slot on the bottom bolt, do that. If it cannot be adjusted there, (and if it has never run after major engine work) the timing gears in front of the governor might be off one tooth. Jim
