Re: 966 Batterys. Charging 2 6 Volts
Posted by Allan In NE on September 15, 2014 at 11:14:11 from (199.47.66.60):
In Reply to: 966 Batterys. Charging 2 6 Volts posted by luv2wrench on September 15, 2014 at 10:53:11:
Yep,
But, an easier way is to hook the positive charger cable to the alternator "BAT" terminal and the negative to the tractor chassis.
Allan
