966 Batterys. Charging 2 6 Volts
Posted by luv2wrench on September 15, 2014 at 10:53:11 from (71.8.214.126):
Quick Question.
To charge my 966, Hook Positive Clamp to Positive Post on the Battery going to starter and Negative Clamp to Negative on the battery with the Negative going to the frame ground? Right?
Use 12 Charge setting?
