Re: 966 Batterys. Charging 2 6 Volts
Posted by mkirsch on September 16, 2014 at 05:12:59 from (72.45.143.81):
In Reply to: 966 Batterys. Charging 2 6 Volts posted by luv2wrench on September 15, 2014 at 10:53:11:
Probably because you were trying to charge them in parallel, by hooking to the + and - of one battery.
That doesn't work. The batteries are connected in series. Two 6V batteries to make one 12V.
You need to hook to the + of the battery that goes to the starter, then the - goes to the frame. It can't help but charge like that.
