Re: Super A 295 2-12 plow setup
Posted by SaTom on September 16, 2014 at 06:31:58 from (32.216.73.212):
In Reply to: Re: Super A 295 2-12 plow setup posted by mkirsch on September 15, 2014 at 13:47:27:
I do have the drawbar reversed and the plow mounted offset to the right. All the wear parts are in excellent shape. The plow has a few of the original metal part tags on it so it wasn't used much. It was on the tractor as a snowplowing counterweight. I'm wondering if the touch control link needs to be adjusted and shortened. There is what looks like a threaded eye bolt near the mounting hitch (it might have been part of a crank, something like the fast hitch crank adjust) that I guess is supposed to be another adjustment that I didn't play with. I have the chains slack when the plow is in the ground. I had them hooked up temporarily to the rockshaft arms because the bar with the chain hooks that came with the plow needs to be fixed.
