Forgot to add--pulling the touch control level back pushes the front of the plow down and makes it go deeper. Push the touch control lever forward pulls the front of the plow up and makes it go shallow. You may need the lever pretty far back to get it to suck into the ground especially on the first pass. You want it to run with the lifting chains slack. The eye bolt is used to level the plow--originally there was a long crank that goes up to level with the steering wheel so you can adjust from the seat. It's just like a 3 point hitch plow, when you're in the furrow you want the plow bottom to be sitting level.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
