Re: C-153 Cam / Crank Timing Marks
Posted by Owen Aaland on September 17, 2014 at 19:23:15 from (216.47.34.49):
In Reply to: C-153 Cam / Crank Timing Marks posted by IH55T on September 16, 2014 at 17:32:41:
I found a better depiction of the timing marks in the I&T manual for the 444. It is a drawing rather than an outdated picture. It also describes the procedure in text.
third party image
When reassembling, mesh the single punch marked tooth on the camshaft gear with the single punched marked tooth space on the crankshaft gear and the double punch marked tooth on the camshaft gear with the double punched marked space on the governor and ignition unit drive gear. Refer to Fig.40.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
