Re: Farmall M Governor Installation Issue
Posted by Bob in wc Ia. on September 19, 2014 at 20:52:28 from (173.20.53.115):
In Reply to: Farmall M Governor Installation Issue posted by johnb5345 on September 19, 2014 at 18:30:40:
John, does the idler gear appear to be square with
the front plate? If the pin on the back side of the
idler gear shaft is not in the hole, this could
possibly be the cause. If everything looks ok maybe
try taking off the governor side plate and turn the
weight shaft as your putting the governor in
place. Bob
