Re: 12v generator on H
Posted by Bob M on January 03, 2001 at 09:08:25 from (192.232.119.194):
In Reply to: 12v generator on H posted by gary on January 03, 2001 at 05:11:42:
Gary - Along with the 12V the generator, you'll need to use the voltage regulator from the 806. If you retain the stock Super H wiring harness and the 806 regulator does not have an "L" terminal, connect the wire that ran to the "L" terminal on the SH regulator to the "BAT" terminal on the 806 regulator.
Also if you're using the stock 6 volt SH coil, be sure to install a ballast resistor in the line between the ign switch and the coil + terminal.
Post A Followup
: Re: Re: 12v generator on H
