Posted by jimb2 on September 23, 2014 at 14:32:48 from (99.241.118.87):
In Reply to: 484 cab tractor posted by tractornutjd on September 23, 2014 at 03:07:07:
Hi, is it gas or Diesel? It is a dry clutch. Determine if it is transmission or engine oil. Can be leaking from transmission around PTO, transmission input shaft and there is also another cover in bottom left of transmission inside clutch housing. See link to 886 PTO, 484 is similar. If engine oil it could be rear main oil seal leaking. You will have to remove flywheel to access. My brother's 684 had been leaking a little engine oil into the clutch housing for years. When we did a clutch job and had flywheel turned, we found the bolts on the rear main oil seal were loose, we tightened them to spec and it hasn't leak since, over 10 years ago.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
