farmall 130
Posted by ken house on September 23, 2014 at 19:32:38 from (173.242.240.3):
130 farmall, starter is not turning motor over very good. may be the battery (6 v). tried to hand crank it. it kicked hard. will not try that again. adjusted timing. cleaned points, while i was there, has not ran since. getting gas. i have a wire soldered to a spark plug, for a tester. cannot get fire. took distributor wire off of dist. grounded it and cannot get fire. ???put coil on another tractor, it started right up. ??? so coil is good.
