Posted by kelly in tx on September 25, 2014 at 17:51:31 from (184.62.19.89):
I have a Davenport wagon running gear. This is a high wheel, steel wheel running gear with bearings. I think it was one of the first wagons made with bearings. (Made about 1904? - 1917???) At any rate I need some thrust washers with about a 2 7/8" inside diameter and 4 1/4" outside diameter and about 1/8" thick. I've tried Fastenal and bearing houses. I'm afraid machine shops will be pricy. Ideas? I don't weld or cut with a torch. kelly
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
