Re: 560 gas motor knock
Posted by Notjustair on September 28, 2014 at 13:43:29 from (174.229.64.78):
In Reply to: 560 gas motor knock posted by Brad Vaughn on September 28, 2014 at 13:28:44:
So when is this knock? It matters. Some mean main bearings, some rod bearings, some are tappet slap against the cam (depending on the engine). It's when it does it that determines the problem.
  Upload Photo  Select Gallery Photo  Attach Serial No List
