Re: bought a saginaw!
Posted by Dan on January 03, 2001 at 20:59:28 from (12.18.161.164):
In Reply to: bought a saginaw! posted by mike on January 03, 2001 at 19:35:26:
Believe what you say is correct. The lift all only operates a single action cylinder. On my SMTA there is a remote valve under the rt side of the fuel tank that will operate a 2 way cylinder. A while bck someone here comented that you would have to plumb the return line into the filler plug of the lift all, run the pressure line from it through a separate valve and block the lift all lever. I would think you could also run the pressure line from the live pump to your new valve, then run the return from the valve into the liftall box on the right side where it hooks up now. Would think that would work but better check with the other guys here
Post A Followup
: Re: Re: bought a saginaw!
