Re: No gas
Posted by roger hall on September 28, 2014 at 23:55:33 from (74.126.67.106):
In Reply to: No gas posted by farmall4856 on September 26, 2014 at 15:26:29:
drain the gas out and strain it through a rag----take the compleat unite out of the bottom of tank-----flush the tank with water and strain it to see whats in there[i use a camper tank flusher] get behind the baffle too--take the line off and blow it out with air---put it back togeather --you will have to drain the bowl two or three times--- only put a gal of gas in it--if that doesnt help it -revisit that carb float you reset
  Upload Photo  Select Gallery Photo  Attach Serial No List
