Posted by farmall4856 on September 26, 2014 at 15:26:29 from (70.192.192.175):
Did a little disking today with the super m. We'll it got about to run on temp gauge when it started to run rough really rough. So I took off bottom drain plug on carb and there's hardly any gas coming out! Just put all new needle in and adjusted float and flushed out tank as well as cleaning the screen plug that goes into carb. What's the matter I need this tractor to pull the disk ASAP!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
