Re: Back to the 560 knock
Posted by Centex Farmall on September 29, 2014 at 20:46:55 from (72.105.166.202):
In Reply to: Back to the 560 knock posted by Brad Vaughn on September 29, 2014 at 18:23:08:
Sounds like those two valves could be sticking a bit and then when they turn loose... BAM.
With that going on several times a minute it doesn't take long for damage to occur. See if those valve springs seem weaker than the rest or if the end of the valve stems are higher than the rest, indicating seat recession.
  Upload Photo  Select Gallery Photo  Attach Serial No List
