Re: Ethanol based fuel
Posted by Mr. Farmall A on September 30, 2014 at 15:59:26 from (68.44.97.85):
In Reply to: Ethanol based fuel posted by mikesbailey on September 27, 2014 at 16:31:55:
Ethanol does cause problems for parts not designed to withstand it, mainly low quality replacement which is what most vendors sell. I have had 3 needle valves fail in a year, the viton tips turning into soft goo causing them to stick and the engine to stall at higher rpms or under a heavy load but idle fine.
Last month, the accel pump in my Chevy started to stick badly and had to be replaced even through it was supposed to be ethanol proof, the seal swelled to 3 times its original size. You need to use high quality parts which are not made for everything.
