Re: Ethanol based fuel
Posted by rustyfarmall on October 01, 2014 at 05:56:50 from (208.126.186.41):
In Reply to: Ethanol based fuel posted by Mr. Farmall A on September 30, 2014 at 15:59:26:
My M has been running on E10 for all the years I have owned it, probably about 12 years. Recently I experimented with E85, and sometime after that I removed the carb and opened it up just to have a look at what the E85 MIGHT have done to it. I found that the ethanol had done absolutely NOTHING at all to that carburetor. Everything was still good to go. Including the viton tipped needle valve. That M also has an aftermarket rubber fuel line. The ethanol has done NO damage to it either.
