Re: farmall m wont start
Posted by castle55 on September 30, 2014 at 16:41:43 from (167.142.37.34):
In Reply to: Re: farmall m wont start posted by John M on September 30, 2014 at 14:21:32:
we were pushing snow and it started popping and missing losing power so we parked it. It would not start after that.We replaced the coil cap rotor points condenser plugs, rebuilt the carb,and then found we had low compression, sent the head in for a valve job and they found a couple cracked valves and the rest could not be ground again so it got new valves and seats. It has good spark and is in time as can be without it running. carb spits fuel while cranking, I don't think it is sucking it all the way to the valves compression 60-60-60-90
  Upload Photo  Select Gallery Photo  Attach Serial No List
