Re: farmall m wont start
Posted by kevinj54 on September 30, 2014 at 17:03:27 from (50.105.85.101):
In Reply to: farmall m wont start posted by castle55 on September 30, 2014 at 16:41:43:
These are static timed so you are in time or not!
Sounds like you better check valve timing too.
Maybe check firing order as well
Your description of the failure does not indicate valves, compression, etc.
