Re: 1456 Aternator, Voltage Regulator, Batteries ???
Posted by Janicholson on October 03, 2014 at 20:24:01 from (74.60.94.18):
In Reply to: Re: 1456 Aternator, Voltage Regulator, Batteries ??? posted by Weldon K on October 03, 2014 at 19:28:21:
Both the resistor Shown, and the lamp filament must be good. Warning lights do go bad, and can cause charge failure. If you check the circuit with a continuity checker, or ohm meter, make sure to isolate the lamp from the circuit. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
