Your suggestion is well and good if one is starting from scratch to get a system to work. However, I have a NEW original style alternator, a new voltage regulator and two new batteries and I want to get these things to work. The systems on these old tractors worked well for me for years and I do not see any reason that they can not work for many more. I just need to know what else there is that may be causing the problem. Could it be the resistor in the porcelain block found mounted just above the voltage regulator? Years ago I found that one of them was bad on another tractor and batteries were not kept charged, but in that case the AMP light worked normally as it should have when switch was turned on and light went off as engine revved up. I believe that I have a new resistor in stock and I will install it tomorrow to see what will happen. Strange thing to me that AMP light is not working only since installing three new components . I guess that it could have burned out but what a coincidence doing when it did, if it did. Perhaps one of the batteries has internal defect and has shorted out.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
