Re: 1456 Aternator, Voltage Regulator, Batteries ???
Posted by T in NE on October 05, 2014 at 00:04:07 from (75.238.147.36):
In Reply to: Re: 1456 Aternator, Voltage Regulator, Batteries ??? posted by Weldon K on October 03, 2014 at 19:28:21:
Set your digital volt meter for ohms and see how many it pulls across the ballast resistor. If it's 0, it's open, which means it's bad.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
