Re: Farmall H Cooling System Question
Posted by Scott L. Swanson on January 04, 2001 at 11:15:42 from (209.180.31.9):
In Reply to: Farmall H Cooling System Question posted by Scott L. Swanson on January 04, 2001 at 11:02:53:
Red, Thanks for the info. I did remove the Thermostat and replace it. Now I wonder if my machine is putting out enough heat to actually open the Thermostat. I need to know if the pump is working before I continue on with the troubleshooting. I know my system is non pressurized because the replacment cap I bought did not fit. Now, after running it hot to try and force the thermostat to open, it continues to heat up the engine and the hoses and radiator stay cool. Is there a way to see that the pump is working?
Thank you very much for the information. You smart Farmaller's are a blessing to us new at the game.
Post A Followup
: Re: Re: Farmall H Cooling System Question
