Re: front rim slipping
Posted by RB on January 04, 2001 at 15:20:05 from (63.27.122.24):
In Reply to: front rim slipping posted by tony on January 04, 2001 at 15:07:20:
You can get the original type bolts at specialty nut and bolt supply house.The ones I bought were like $3.00 a peice,but for looks its worth it.What I didi on my working M is take two fenderwashers and drill them out to fit the bolt.Put them on the casting side and a lock washer on the other.The fender washers are flexoble enough to bend into the cast side and keep it from spinning while you tighen the nut.
Post A Followup
: Re: Re: front rim slipping
