H/M factory widefront aftermarket spindles Part numbers
Posted by primerk5 on October 13, 2014 at 06:28:50 from (20.132.68.134):
I picked up a adjustable wheelbase wide front for an M/H. One of the knuckle/spindles was broken off. I've found an aftermarket spindle/knuckle that i think might work. Per the IH parts catalog the PN is 51699DF. Per this site and a few others the Aftermarket one is a replacement for 51699DE. I can't find that part on the CASE IH site. I'm thinking the DE may not be the correct p/n.
Here is a link to the aftermarket part.
https://www.yesterdaystractors.com/51699DE_Spindle-LH_7092.htm
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
