Re: H/M factory widefront aftermarket spindles Part numbers
Posted by D Slater on October 13, 2014 at 08:27:27 from (184.14.184.128):
In Reply to: H/M factory widefront aftermarket spindles Part numbers posted by primerk5 on October 13, 2014 at 06:28:50:
If the spindle was manufactured during the H and M time period it probably has a 51699DE or lower suffix on it. DF has some change to the part but still works for DE. DF suffix was the last spindles IH sold. When IH sold the spindles they included the wheel bearing nut and a washer with them to take the place of the one piece nut and washer with a clamp bolt used on tractors before a serial number break. Serial number break really doesn't work since a lot of wide fronts were added or switched around.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
