Re: front rim slipping
Posted by David Saville on January 04, 2001 at 18:17:53 from (142.165.5.142):
In Reply to: front rim slipping posted by tony on January 04, 2001 at 15:07:20:
If you look carefully at your rim you will probably find a spot where a locking lug has fallen off. It is about 1 inch by 1 inch and fits into the back of your cast iron wheel in a notch halfway between two bolt holes. This lug is what keeps your rim from slipping not the bolts.
Post A Followup
: Re: Re: front rim slipping
