H battery placement
Posted by jsr8011 on October 18, 2014 at 12:34:17 from (69.47.196.108):
the PO bolted a piece of plywood to the angle bracket to hold the battery. I use a nylon strap to help keep it in place which generally works OK, but with vibration it tends to move around a bit. What do you suggest I do for a better solution. I'm not trying to restore the tractor to original. Just want something solid.
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
