Re: H battery placement
Posted by El Toro on October 18, 2014 at 14:17:59 from (96.244.7.206):
In Reply to: H battery placement posted by jsr8011 on October 18, 2014 at 12:34:17:
I would have a metal battery box made at your local metal shop. Take the battery along. I would paint the battery box inside and out using a good primer and finish coat of acrylic enamel.
Hal
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
