Posted by c1802362 on October 18, 2014 at 12:42:02 from (68.224.198.81):
I just put my '41H back together. I had the head off (3 cracks in the head between the dome and coolant holes), but left the block, magneto, distributor, governor, etc alone while I was working on the engine.
With the new head/valve job installed, I set the valve lash, put everything else back on and went to start the engine. I also couldn't locate Champion D18Y spark plugs, so substituted NGK AB-6 plugs (supposedly they are interchangeable)
The battery had been drained, so the charger was hooked up. The engine cranked normally, but refused to fire. The distributor cap looks pristine (as does the rotor) and the wires are in good shape.
I pulled two plugs and held them up against the block while I cranked the starter. No spark.
I pulled the coil wire from the distributor and held it up against the block. Weak spark.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
