Re: '41H won't start
Posted by Charlieu on October 18, 2014 at 16:22:07 from (206.53.193.32):
In Reply to: '41H won't start posted by c1802362 on October 18, 2014 at 12:42:02:
third party image
Here is a little trick that works for me. If you have a battery ignition system hook up a test light to the primary terminal of the distributor and connect the other end to ground. Turn on the ignition switch and crank the engine with the starter, if the test light flashes, that tells me that the points are opening and closing making ground connection.
  Upload Photo  Select Gallery Photo  Attach Serial No List
