Re: 2400A or 454 PTO Issue
Posted by jimb2 on October 21, 2014 at 13:29:30 from (99.241.118.87):
In Reply to: 2400A or 454 PTO Issue posted by JeffatSE on October 21, 2014 at 13:04:30:
Hi Jeff, simple things first, check for junk that has gotten down behind seat that is interfering with the PTO engagement lever. Next the PTO engagement lever actuates a hydraulic valve on top of MCV valve where hydraulic filter is mounted under the left foot rest.
See item #35 at:
http://partstore.caseih.com/us/parts-search.html#epc::mr63400ar620739
Take your favorite penetrating oil and spray all the PTO lever mechanism parts including under the rubber boot on top of MCV valve.
If above doesn't fix the problem then possibility is PTO clutch pack, hydraulic pressure to PTO clutch pack. I don't believe the splines in the pressure plate are stripped as all the hydraulics would stop.
JimB
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
