Posted by bassmasta76 on November 03, 2014 at 08:55:41 from (198.232.50.162):
Ok, so I finally got my H running over the weekend. After having it sit for 6+ months while doing minor work, replacing most of the ignition system, etc. It's running, mostly.
The problem I'm having, that it seems like a lot of others have (or have had), is that the carb leaks out of the weep hole. The carb was fully rebuilt and the float is good. I initially adjusted the float as recommended, but it kept leaking. I adjusted it higher and the leak largely stopped.
That being said, I know that these tractors dont need to be choked, and when the choke is applied (as a test when I was trying to get it running), a lot of fuel comes out. If the choke is wide open and the air filter disconnected, I get no fuel leak. The moment I put the air filter tube on the carb and start it up, it starts leaking again, almost like it was being choked.
Maybe the issue is the air filter? I cleaned the whole unit and replaced the oil in the cup with SAE30. Any suggestions? I was going to try raising the float even higher to see if maybe that is the issue.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
