Re: Is this normal?
Posted by rustyfarmall on November 04, 2014 at 11:30:52 from (208.126.186.41):
In Reply to: Is this normal? posted by kleinerpiner on November 04, 2014 at 11:04:12:
5/16" fuel line is correct for nearly all of the letter series Farmalls. I have also found that whoever packages those items for the farm supply type stores, really know very little about it, and packaging is often mis-labled, or maybe the item in that package is NOT what is supposed to be in it.
Just educate yourself before-hand. I've also learned that the genuine article from Case-IH may not be all that much more costly.
