Posted by Janicholson on November 04, 2014 at 11:46:24 from (199.17.6.25):
In Reply to: Re: Is this normal? posted by michaelr on November 04, 2014 at 11:09:26:
Not a Flame)) With a Gravity system, the solidity and reliability of steel line is considered best practice. Fuel filters in a gravity system need to be designed for that task, common plastic filters are a source of frustration with low force transfer of fuel. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
