Re: Is this normal?
Posted by michaelr on November 04, 2014 at 11:09:26 from (216.66.79.38):
In Reply to: Is this normal? posted by kleinerpiner on November 04, 2014 at 11:04:12:
I don't know, I normally put a rubber flex fuel line on to replace the copper tubing, that way I can put a fuel filter between sediment bowl and carb.
  Upload Photo  Select Gallery Photo  Attach Serial No List
