Re: Do you need to remove frontend to remove radiator on M?
Posted by DeltaRed on November 06, 2014 at 08:13:13 from (65.100.145.34):
In Reply to: Do you need to remove frontend to remove radiator on M? posted by unioncreek on November 06, 2014 at 07:46:38:
Depends. If the factory 'setback' plate has holes in it to access the bolts,no.If the plate has not had holes cut in it,yes.An aftermarket front may or may not have access holes for those bolts. The only way to know for sure is to crawl under and LOOK.If there are no holes to access the bolts,yep,ya gotta drop the front.While the front is off,make two holes(those holes are usuually 'cut' with a torch) in the plate,so the next time the radiator needs to come out,the front can stay on.
  Upload Photo  Select Gallery Photo  Attach Serial No List
