Where do I check/drain trans fluid on a Super A
Posted by BIG on January 06, 2001 at 07:26:38 from (63.25.48.93):
I want to replace the trans fluid on my 1948 Super A (serial # 260001). I know that you check it by removing the plug on the top of the trans close to the shifter but, where do you drain it? How much do I put to refill it after I drain? What fluid do I use? Also, if it applies, I do have the 90 degree gearbox in back for mounting a belly mower and such. Does this lube with the same oil or does it need to be draind and refilled seperately? It also has hydraulics - does this have a seperate reservoir and what fluid it does it need? Thanks for any information.
Post A Followup
: Re: Where do I check/drain trans fluid on a Super A
