Re: Is this normal?
Posted by Lmack on November 06, 2014 at 13:25:39 from (24.131.50.165):
In Reply to: Is this normal? posted by kleinerpiner on November 04, 2014 at 11:04:12:
It may be hard to maintain fall without a low point using a rubber hose. I have tried rubber but converted to steel as soon as it became obvious that the up draft carburetor would not work well without a dependable fuel supply. I have made several fuel lines from new break line stock and they have worked just fine. Original equipment was not copper but steel for the letter series.
  Upload Photo  Select Gallery Photo  Attach Serial No List
