Re: Farmall H flooding/fuel running on ground
Posted by redforlife on November 06, 2014 at 17:32:31 from (68.234.121.124):
In Reply to: Farmall H flooding/fuel running on ground posted by getitrunning on November 06, 2014 at 14:20:14:
You are choking it to much/to long. Probly to the point you are flooding it if its not starting. Basicly when full choking, you are shutting the air off, and the engine is sucking liquid gas out of the carb. Thats what is running out the bottom of carb when you quit cranking. It shouldn't take hardly any full choke to get it going. 1/2 or maybe 1 engine revolution and it should be fireing. Once it starts you may have to adjust choke to a partial position untill engine is warmed up. Over choking is your problem, and that extra gas running out bottom of carb is normal when that happens.
  Upload Photo  Select Gallery Photo  Attach Serial No List
