Farmall H flooding/fuel running on ground
Posted by getitrunning on November 06, 2014 at 14:20:14 from (207.61.204.244):
Hi - I have a 1949 Farmall H, was my grandfathers & fathers until it stopped being used in the mid-80's. I have got it running again, with a number of refurbishments, etc. My problem is that it floods easily and if it doesn't start in the first 10seconds or less, I have fuel running out of the bottom of the carb fairly fast. I'm not sure that's the problem or the symptom, but it doesn't seem like it should be doing that.
Today I had the lower half of the carb off so I could look at the need and float valve. My needle doesn't have a rubber tip like I've seen on some, but it doesn't leak when the tractor is off, or when running, only when failing to start. So I assume that the needle is closing sufficiently or it would leak all the time?
Otherwise, is it pumping too much into the carb when trying to start, or is there another issue? I adjusted the main fuel screw and the idle adjustment screw today to the book's settings (2.5 turns out and 1 turn out, respectively), but that didn't change anything.
Thanks
Michael
