Re: Farmall H flooding/fuel running on ground
Posted by getitrunning on November 07, 2014 at 06:01:05 from (207.61.204.244):
In Reply to: Farmall H flooding/fuel running on ground posted by getitrunning on November 06, 2014 at 14:20:14:
Thank you everyone. I have experimented for a while to get the right combination of things at startup. I have started it more often lately with a quick pop of the choke out and back in. But it hasn't started well lately (I am getting new plugs today) and I end up doing a bit of cranking in my attempts. It will eventually start dripping that way too ....... but the choke is eventually more and more out as I try so maybe it I didn't do any choking it wouldn't do that.
It also has lower compression on some cylinders, I believe that would cause difficulty starting too? And the plugs get fouled easily because I don't use it for any heavy jobs, usually just as the extra tractor needed to run an auger on PTO.
