Re: IH 674 ? 2 reservoirs
Posted by John Zitkus on November 09, 2014 at 16:03:13 from (70.196.71.255):
In Reply to: IH 674 ? 2 reservoirs posted by jimb2 on November 08, 2014 at 05:54:16:
JimB2,
not much of a tractor mechanic, but I checked all the
gears in the pump enclosure none would move more than app. 1/8". Just behind ( to the rear ) the pump gear there is a
cluch like device it moves app. 360 Deg. and hits a stop.
I am thinking this is to engage the PTO. I am starting to
put my money on the MCV if the pump dosen't fix the
problem. I did not look in the clutch inspection plate,
(wasn't sure which plate it was the one with 11 bolts
or the two bolt one with the cottor pin sticking out the
bottom). also wasn't sure what you meant by T/A.
This tractor has had many modifcations it appears many
things have been bypassed or disconected. I am still trying
to figure out where to connect a new Tachometer cable.
allmost all wireing harness has been removed.
Thanks in advance for any help you can give me.
I just recently retired and want to work on these
great work horses as a passtime and to work my farm
Thank You
John Zitkus
